A couple of hints: Those curves (chamfers) between the risers really don't need to be so curvy unless you're going to zoom in and show an extreme closeup of those particular surfaces. Poser just loves to round things off, which is a problem in other circumstances but a virtue here. Probably a three- or four-slice curve will do just fine, which will give you much more controllable tesselation on the side of each step. Also, if you build the side rails as separate pieces (which will end up as separate Groups in the result) you can avoid the tesselation on them entirely. They can be plain old quadrilaterals.
My python page
My ShareCG freebies
Nope. Only quads in that model, there's a short edge on the side face at the nosing of each step, it connects those chamfer lines. Hard to see in the pic, but it's there. And in my experience, poser deals with more than 4 sides just fine, provided the face is a simple, roughly circular shape (L-shaped or U-shaped will no doubt cause problems). In hundreds of models I've never once had a problem with an n-gon in Poser.
