Mon, Feb 10, 10:28 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Can an actor be locked via Python?
destro75 ( ) posted Sun, 02 April 2006 at 2:20 PM · edited Mon, 10 February 2025 at 10:10 PM
I am trying to lock a light in place. Is this possible in Python? I can't seem to figure it out. TIA!
nruddock ( ) posted Sun, 02 April 2006 at 5:02 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2516892
Not sure that this is useful for lights, but see attached link.
To get a light to stay in the same place relative to something other than the Universe, it can be parented and pointed at (an invisible prop may be needed for correct targeting).
More details would produce a more exacting answer.
destro75 ( ) posted Sun, 02 April 2006 at 7:20 PM · edited Sun, 02 April 2006 at 7:20 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2637757&Reply=2638305#
Hey Noel,
What you discussed is exactly what I am trying to do. Someone was asking about parenting lights to an object, holding the lights in position. I was trying to do this using just one primitive for the target, but not actually having the lights pointing at it. I just want the lights to keep whatever position they were already in, but be parented to the prop.
Does this make sense? Thanks for the help. Lou
Message edited on: 04/02/2006 19:20
destro75 ( ) posted Sun, 02 April 2006 at 10:13 PM
Okay, I think I worked around it well enough. Thanks.
