Works fine for me. Steps I take. 1. pose figure. 2. add clothes. 3. comform clothes to figure. 4. use magnets to fix any bad spots. 5. export as OBJ. 6. uncheck all of the clothes parts that are suposed to be hidden. save. 7. import into Bryce. that's it Spike
You can't call it work if you love
it... Zen
Tambour
Nope, I can assure you guys that it isn't 3D Explorer that is causing the errors. I had the errors before I installed it! But what I have also discovered is problems exporting with .3ds props. Poser simply doesn't export them at all. There is one thing that you can do and that is export them one at a time. Tedious I know, but if you export only the skirt and then export the figure they usually won't give you the "invalid format" error. Good luck! Regards Ronin
Has anyone had any success exporting poser 4 clothing that is conformed to a poser model? Everytime I export it a poser model with posable clothing "conformed" and try importing it into Bryce, I get an error. Any one have any success with with this? It's REALLY annoying to have to export the clothes seperately and try to line them up in Bryce. Thanks.
