Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Oct 21 8:28 pm)
Critter, I cannot replicate this mistake. I created a box with a texture, made the Trans Min 0, the Max 100, and set falloff to 0. I imported this into Poser 5 and 6, and both times my fallof stayed at 0. Are you importing this to Poser 5 by linked runtimes, physically moving the prop to Poser 5, or saving as PZ3 and opening this in Poser 5. Once I can replictae the mistake, I can see what is causing it. Maybe if you could show screenshots of the material in Poser 4 and 5 we can pick up on something. Helgard
Your specialist military, sci-fi, historical and real world site.
3dCritter
Critter, glad you sorted it out. Just a suggestion, I see you have no bump map on the fence. I have made a few fences and grids and things, and I find the addition of a bump map greatly increases the realism of the fence, especially on things like barbed wire.
I have a material than uses a transparency map - the Trans Min is set to 0&, the Max to 100% and the falloff is 0. I created the .pp2 files in Poser 4 and everything renders fine there, and the tExpo value for the material in the file is definitely 0. But when I import the files into Poser 5, the Transparency_Falloff value changes to 0.6 and does not render properly.
3dCritter
