If Vue doesn't ask where to save, it's strange. Are you sure you can save the alpha map? If you rendered at a size that doesn't fit your screen (bigger)you neeb to enable the alpha map to be rendered in the g_buffer, otherwise, you won't be able to save it. You can see it on the screen, but without the option to save. Happened to me a few times, and this is terribly annoying. Now I know I need to enable the g_buffer to be able to save it.
Thanks redtec! Unfortunatelly you have to check twice (in the render options + g-buffer) so that Vue REALLY can save it; otherwise Vue won't save even if you see the alphamap and clicked on "save": it simply won't save "physically" (and it won't give you an error message either) if you didn't check the box in the render options.
By the way; I thought when you make your "Final" render it will antialias your pic. To my amazement I discovered that it won't texture antialias until you pick some of the higher quality render options (Superior...or user picked) doh! I didn't understand why my 2 first pics were so grainy but now I've learned!
I observed a pretty stupid thing in Vue5 Inf. When I finished my render (with the alpha map option checked) I clicked on the tiny alpha icon (to the right in the window) and wanted to save it but I don't know where the image goes to! (I see the rendered alpha map on screen) I right click and the popup says: "Save this image" - OK! Now I would like to know where the h*** can I find it? I went through the main folders (where the color pic is saved but no sign of the alpha pic there or in the Vue folder; I can't even give a name to the alpha pic or browse a correct folder where I can save it - it only disappears into somewhere/nowhere so now I pulling my hair! Any ideas, suggestion? Thanks Atte
