Community Center F.A.Q (Last Updated: 2024 Dec 17 9:40 pm)
Seems to be the Forums link at the top of the page is hosed.
Apparently, they decided to add an additional column to the database table of the finished and out of testing forums after declaring them finished.
Should clear up in a bit once they fix the code on that page if not already.
Quote - Apparently, they decided to add an additional column to the database table of the finished and out of testing forums after declaring them finished.
Actually the new column was in our member table, not a forum table. When joining, there were now two columns in different tables named the same thing, so it was "ambiguous". The problem is fixed now.
-Nicholas
As stated above. I have to use the forum jump box to get anywhere.
Thanks
