Fri, Feb 7, 12:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Problem with retiming BVH files
ulysses ( ) posted Wed, 04 April 2001 at 10:01 AM · edited Fri, 07 February 2025 at 12:23 AM
I probably shouldn't be complaining since the BVH files included with Poser are pretty cool but I wanted to see if anyone else experienced problems when you retime an animation using an imported BVH. An example is one of the Dance Studio bvh files. When I apply it to a figure and then want to slow down the motion using "Retime Animation" sometimes it will randomly generate spazzy motions where there wasn't any in the original-speed animation. Arms will flail and sometimes the body of the figure will go completely horizontal for a frame or two. I can adjust these problems manually but for my own info I was wondering if any one had idea what's going on. thanks
JKeller ( ) posted Wed, 04 April 2001 at 12:35 PM
When you import a BVH into Poser, every frame throughout the durration of the animation is keyframed, leaving Poser no room to interpolate any of the animation. When you are slow down your animation, you are spreading your current keyframes over a larger area of frames. This will give you frames in your animation that aren't keyframed, and the little gnomes inside your computer get hard to work on iterpolating or 'tweening' the areas between your keyframes.
The problem lies in the fact that because Poser uses spline interpolation by default, and there are so many keyframes, it causes little loopty-loops in your animation path. Spline animation does great things with a few keyframes over a long period of time, but because the keyframes are still so close together you get these quirks.
To fix it, open up your Animation Palette, drag your selecter to select all of your keyframes in the animation and then hit the orangish "Linear" button in the controls on the upper right side of the palette. Now movements will be in a straight line from keyframe to keyframe, but with so many keyframes you'll probably still have very smooth motion in your animation.
Hope this helps.
poserpro ( ) posted Thu, 05 April 2001 at 4:20 AM
same to me will try thy tip later. Thanks.
ulysses ( ) posted Thu, 05 April 2001 at 10:41 AM
Thanks very much for the info, Jkeller. I will give it a try. While we're on the subject of BVH files, does anyone have the Motions CD from Daz3D? Do you find it was worth the $90? thanks,
Jim Burton ( ) posted Thu, 05 April 2001 at 12:39 PM
Attached Link: http://digitaldreams.bbay.com/
I've got it, I think it was well worth it. The SMV movie on my website was done from it.
timoteo1 ( ) posted Thu, 05 April 2001 at 5:32 PM
THANK YOU!!! THANK YOU!! THANK YOU ULYSSES!! I just posted a message on the board about some unknown BVH files I had. Your post reminded that I had bought the Motions CD but never tried it out. I then was checking out the CD when I noticed some of the BVHs were the same as the ones I was wondering about. MYSTERY SOLVED. Well, I still don't know how the heck I got them ... they must have been free samples. I concur with Jim, they are VERY good. They are done by the House of Moves people. HoM is generally better than Credo IMHO and, their BVHs actually work VERY WELL with Michael and Victoria. They are Z-axis BVHs ... don't know if that has anything to do with it. I think it is the skeleton they used rather. That reminds me ... I need to post some news about BVHs for everyone. Anyway ... thanks again!!! -Tim
timoteo1 ( ) posted Thu, 05 April 2001 at 5:33 PM
PS> JK, very nice fix and explanation. Another option would be if you are editing a movie together you could just slow it down in your editing software of course. Regards, Tim
ulysses ( ) posted Fri, 06 April 2001 at 9:19 AM
Thanks for the replies. I will be getting the Motions CD based on your recommendations. I'm always looking for BVH files so if anyone knows of any good sources of freebies on the net please let me know. I recently created a movie using two skeletons with top hats doing a synchronized dance, using one of the Dance Studio BVH files. It's part of a company-sponsored event to promote math and science to 8th-graders. It got a big response.
poserpro ( ) posted Fri, 06 April 2001 at 9:34 AM
I have 50 Free BVH, based on "non-dance style" dance studio files.
timoteo1 ( ) posted Fri, 06 April 2001 at 10:44 AM
PoserPro: Are they in freestuff?
poserpro ( ) posted Fri, 06 April 2001 at 10:53 AM
julien@arrowweb.com, mail me for free.
