Mon, Jan 20, 12:06 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: high-res-maps
thor1 ( ) posted Thu, 19 August 1999 at 3:52 AM ยท edited Sat, 28 December 2024 at 1:57 PM
hi what do i have to do, if i want to make a higher res-mapping (e.g. for the catsuit for p4-add.clothes)?? can i convert them simply to a higher resolution, or will the map then fit no more?? i have to render a high-res-figure and if i use the default-template in 72dpi in default size its very pixelized.....
grey ( ) posted Thu, 19 August 1999 at 3:58 AM
Download UVMapper Load the OBJ file you want to use Reset the resolution export the Image (don't save the OBJ though...)
bloodsong ( ) posted Thu, 19 August 1999 at 7:58 AM
heya; grey, why can't we just reset the resolution of the texture? i was messing with my zebra texture at different resolutions up to 300 dpi in photoshop, and they all seemed to fit okay. as long as you don't change the proportions, right?
Foxhollow ( ) posted Thu, 19 August 1999 at 4:40 PM
You CAN just change the resolution in your paint program or anyway you like. The texture mapping is resolution independant...just be sure the acpect ratio remains the same.
grey ( ) posted Thu, 19 August 1999 at 11:27 PM
Bloodsong, you can, sure, but you wont get the High Rez image of the Geometries...a nd that can be important
bloodsong ( ) posted Fri, 20 August 1999 at 7:58 AM
ohhhhhhhhh.....!
