Sun, Feb 9, 7:08 PM CST
Subject: Reordering of parameter dials
Gem_719 ( ) posted Wed, 04 April 2001 at 7:54 PM ยท edited Thu, 06 February 2025 at 10:26 PM
I've been adding new morph targets (parameter dials) to a figure and now have a problem with them. When I try to reorder them in the hierarchy editor using drag-and-drop they will not move to the new position. They stay just where they were before. Is this a Poser bug? Is there a way around this?
bloodsong ( ) posted Wed, 04 April 2001 at 9:08 PM
heyas; you need to move them in either a text editor (ugh!) or a cr2 editor. check the free stuff for one.
Hdrider ( ) posted Wed, 04 April 2001 at 10:21 PM
Hello, Another way would be to open the cr2 in MorphManager 4.0. Open up the cr2 in both windows and delete/add in the order you want. Be careful though and don't accidentally save the file without your morphs (from experience..). Later...
No good deed goes unpunished ...
Kevin ( ) posted Thu, 05 April 2001 at 10:06 AM
You can, IIRC, place the morphs in any order, either before or after the main parameter dials. But if you change the order of the parameter dials bad things often happen, so don't do that. And yes, you do need to do this outside of poser.
Gem_719 ( ) posted Thu, 05 April 2001 at 11:20 AM
I looked into using a text editor first. You're right bloodsong - ugh! So, then I wanted to try MorphManager. It's not in Freestuff and the links I found when I did a search in Poser Forum lead to deadends. I'm gonna post a plea for the whereabouts of it in a new post. Thanks people! :o)
