Wed, Dec 25, 10:19 AM CST
Subject: Blurred backgrounds in Poser6
mask2 ( ) posted Tue, 18 April 2006 at 4:34 AM · edited Thu, 08 August 2024 at 1:09 PM
Hello,
 in Poser 6 (with Firefly) when I render DAZ Cyclorama backgrounds they always appear blurred if compared with renders with Poser 4 option (Anti Alias turned off).
Is there a way to sharpen the image with Firefly/P6? (Depth of field is always turned off).
Thanks for help
Mario
semidieu ( ) posted Tue, 18 April 2006 at 6:44 AM
It's probably your Maximum Texture size. Simply increase it in the advanced feature of the render settings.
chinnei ( ) posted Tue, 18 April 2006 at 8:47 AM
Also, something else to try it out is connecting the image node to the ambient color, instead of diffuse, and adjust the ambient value to somewhere between .5 to 1 depending on your scene and lighting.  I know this probably has nothing to do with render being blurry, but in Poser 6 and 5, Daz'a cyclorama renders much darker than in poser4.  Just something else to keep in mind.
TrekkieGrrrl ( ) posted Tue, 18 April 2006 at 10:30 AM
Also... what render settings do you use? The default one is what you can call "draft" mode, it blurs pretty much everything.
mask2 ( ) posted Sat, 22 April 2006 at 11:03 AM
Thanks guys!
Indeed it was the Maximum Texture size
