Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 12:55 am)
If I am not mistaken, I believe the author rendered the figure by itself without the background. Then all you have to do is export that as TIFF or PNG and open it in photoshop and load only the figure. Then you add your background as a separate layer underneath the figure. So, if you erase any part of your rendered figure layer, it will only erase the figure only.
Attached Link: Background
If you are going by the tutorial, the author has already provided the background.All you have to do is open that picture in photoshop along with the picture of your figure. Then just do the drag and drop the background layer onto the figure layer. Of course, you need to resize or crop one of the image as necessary to fit together, although you could just render the figure image in same size as the background.
OTOH, if you are creating your own, then you would need to do two renders. One for the figure only and one for the background only. Export each render from poser as TIFF, and open them in Photoshop and follow the above step.
Let me know if you got this far.
going off in left feild (I'm left-handed, so I'm entitled..;), another possiblity is to just render using the background, find the parts in Poser characters you don't want to display, double-click, and uncheck 'visible' from properties.. (I only have the Gimp, so I'm not much help with Photoshop..;) just an idea..;)
Open up the figure image in PS, go to Select menu, click on Load Selection. Once you get new menu, make sure that channel is set to Alpha, and click ok. It'll then highlight the figure by itself. Then go to Select menu again and click Inverse. Then all you have to do is hit Delete and now all you have is image of figure by itself.
Now, as for drag and drop, first make sure you are using the background image window. Then at the layer palette, as shown by the image above, click and hold the layer (here, indicated by "Layer 1"), then drag that layer across to the window of your figure image. Once, you drop that layer, now you will see two different layers shown on the layer palette of you figures image.
Well, glad I could help out but you did most of the work.
That came out great btw.
Personally, I would've done the reflection and the background all in the Poser, instead of PS, because I could never get the angles and lighting on the figure right if I do it separately. Seems like you got a better handle of it than I do.
Don't know if it helps but saving as .png preserves transparency so you don't have to worry about alpha channels. I would render the image without the background and save as .png then render the background and save as whatever you prefer. Mix the 2 in your image editor of choice and you should be able to achieve the results you desire.
ok..it's obvious I didn't read the tut..;)
Actually, what I had in mind was to do the Poser pic, and if you want to hide parts of the body, etc., you double click on the area, and uncheck the 'visible' part, and it doesn't show up (at least in
Version 4, which is what I have). You can also unclick 'cast shadow', which can be useful at times..;)
You can then do all the other parts of the pic in Photoshop, set it the way you want, then 'Import, Background Picture', and do it that way. May not be what you want, but it was how I read it.
Pakleds are not known to be smart..;)
This is a hard question to ask so I'll do my best
:blushing: After I render a picture from Poser, I want to erase certain parts of the model within Photoshop CS 2 without erasing the background. I have no clue how to do that. I'm actually trying to follow a cool reflection TUT
http://www.uniquerenditions.com/ParadiseWaterTutorial/BatherTutorial.htm
by Linwhite but I get lost when trying to erase portions of just the model. TIA.
Adrian
