Fri, Feb 7, 3:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: ShaderWorks - Preview (or Pre-text) and asking for some helps...
semidieu ( ) posted Fri, 21 April 2006 at 1:33 PM · edited Mon, 21 October 2024 at 11:25 AM
Attached Link: ShaderWorks by semidieu
I have created an application. It works under WinXP, with the Framework 2.0 installed.
Actually, the version available on my website only need the Framework 1.1, but i upgraded my coding application and, with the new version, you will need the Framework 2.0.
The "new" version is nearly finished, but before sharing it, i want to redo my website and do some help files. And here comes the trouble. I'm french speaking and my english is approximative. So, i'm looking for some peoples who could help me correct the helps files and some sentences, like the descriptions below.
Also, i'm looking for some beta tester. I would like to say that all beta tester will receive, for free, the application... but the application will be free ;-) So, there is no reward, only by thanks.
I must check one or two things before putting the new beta version on my website. Also, i do not want to create all the help files if nobody is interested. I know how to use my application, so i don't need help files.
Here are some descriptions of the actual modules. For some of them, you can have more info on my website (with the "old" version).
Informations
Simply gather information from any Poser files: textures files, geometries files, maximum texture size, displacement and raytrace.
Also, you can save this file with and all his references to a folder, keeping the folders structure.
Olivier's Cartoon Shader
This module allows to quickly play with the incredible Art Materials: Toon by Olivier Vinet available at Runtime DNA
ZIP File Installer
Install your Poser files where you want. You can choose your runtime,  your folder, rename the folders, etc...
Cateogries Maker
Create categories for Figures, Hairs and Props. You can save as a CAT pose; or add the categories directly to your file.
Runtime Prefs
Add one or all runtimes in a folder, delete a runtime from the LibraryPrefs.xml. You can reorder them as you want, by a simple drag and drop feature.
Not useful, but you can also get the folder size of all your runtimes.
Runtime Organizer
You can move or copy all references (textures and geometries) from any runtimes to another to match the references in all the files from the library.
This is useful when you split to runtimes or if you have create a product and wish to have all the references.
MAT Converter
Convert Poser 4 files to Poser 6 (add the ShaderTree information). It has a lot of options.
Also, it automatically create a new thumbnails, with a little P6 logo.
Material Mixer
Allows to quiclky change the textures from any Poser files. You can quickly create MAT pose from template.
Also, you can "mix" two different MAT pose, for different figure (Victoria 3 and Miki for example). It does not modify the textures, but only the structure of the MAT file.
MAT Organizer
Allows to quickly move MAT pose files from the Pose library to the Material library. You can also change the runtimes.
It allows to exchange the MAT files from these libraries: Camera, Pose and Materials
Save Face Room Info
Using the Posermatic technic, allows to save the face room information. You can share your faces without sending pmd or obj. And the best of all, the files are incredible little in size.
Change Figure name
Simply change the figure name... Instead of having Figure 1, you can have Victoria 3
Voilà... Hope it will interest some peoples. Please, let me know if such an application may help you in your Poser life.
Thanks for your reading,
semidieu
BARTWORX ( ) posted Fri, 21 April 2006 at 1:50 PM
Thnx looks good i think i can use this verry well....
If i find something ill report it to you !!
Chris
Not used anymore
ghelmer ( ) posted Sun, 23 April 2006 at 11:27 PM
**semidieu!!!  ShaderWorks is amazing!!  You did a fantastic job on it!!  I'm trying it out and loving it!!! **
HUGE THANKS!!
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
semidieu ( ) posted Mon, 24 April 2006 at 8:59 AM
You're welcome !
I'm putting some last things in the "updated" version. A new module and the docs are fninshed. I hope to make the update avaiable this week (the docs will still be in "read and correct" process, but i think they are good enough to understand the basics.).
