Wed, Feb 5, 7:44 AM CST
Subject: Need Help Placing Tattoo Image Directly On Seam of A Skin Texture
Pandorian ( ) posted Tue, 25 April 2006 at 12:37 PM · edited Wed, 29 January 2025 at 11:33 PM
Howdy, I wanted to know if there is a simpler way of applying a tattoo image onto the "seam" of an M3 skin texture as opposed to making two copies of the tattoo on separate layers in PS and then attempting to line them both up on opposite sides?
For example, I'm trying to line up a tattoo directly onto the outer bicep of an M3 skin texture, but as we all know, those skin textures are split right down middle of the entire length of the outer arm, so placement of a tat directly onto the outer bicep region would result on placing it on the actual seam.
Any help with this would be greatly appreciated as it can become very time consuming to line up two halves of a tattoo image directly on the seam of a texture.
Thanks in advance....
Pandorian
Pandorian's Website.... aka......
SamTherapy ( ) posted Tue, 25 April 2006 at 1:13 PM
There's no easy way to do this but a good seam guide is invaluable.  I always try to make a point of doing something like this in my products because it's damned difficult.
Seems like you have the right idea; make two copies and line them up.  Scaling sometimes helps if it's a repeating pattern, because you can ensure the two ends fall together properly where they meet.
Something which may help is to paint a white stripe round the arm, showing where the tattoo will fall.  You will then have a much clearer idea of any linear distortion you will have to account for.  As for the seams, though, well, that's where patience comes in. :)
Pandorian ( ) posted Tue, 25 April 2006 at 1:25 PM
That's what I was afraid of.  :)  But I do appreciate the feedback SamTherapy.
Thank you.
Pandorian
pleonastic ( ) posted Tue, 25 April 2006 at 3:02 PM
Attached Link: http://www.terabit.nildram.co.uk/tattoo/index.htm
yeah, there is a much simpler way -- use a 3D paint program. most of them cost a fair bit of money, but i just found out that there is a free (for non-commercial use) one, terabit's tattoo. i haven't tried it yet, but the price is certainly right.
Pandorian ( ) posted Tue, 25 April 2006 at 4:07 PM
Actually I have a 3D paint program (Deep Paint) but am not really familiar with it as I've never really had the opportunity to play around with it.  Maybe I'll open her up and see what I can make of it.
Thanks for the idea pleonastic.
Powerdots
ockham ( ) posted Tue, 25 April 2006 at 5:17 PM
You could try the 'second skin' technique.  Use the grouping
tool to pick out the facets where you want the tattoo, then
hit 'create prop' to make a separate little piece with the
exact same shape as the original arm.  You can then
treat this piece like a clothing item.  (Sort of like a glove
or hat.)  UVmap it, give it a transparency and texture, and
smart-prop it to the arm.
My python page
My ShareCG freebies
momodot ( ) posted Tue, 25 April 2006 at 7:02 PM
Brilliant Ockham! Simple and brilliant!  Also means that the tattoo can go on a small map that is easily changed. Any news re. loader :)
Miss Nancy ( ) posted Tue, 25 April 2006 at 7:10 PM
either that, or slap a new map on the arm group, in case you need morphs to function. maybe apply some perspective UVs (probably wouldn't work well) or do some kind of manipulation in UVMapper Pro or other mapping software.
Pandorian ( ) posted Tue, 25 April 2006 at 7:48 PM · edited Tue, 25 April 2006 at 7:48 PM
Thanks Ockham, that sounds like a winner.  I'll give it a shot.
Pandorian
