Sat, Jan 11, 11:10 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Help! I moved files and messed up Poser6 Python dir.
muralist ( ) posted Thu, 04 May 2006 at 7:08 PM · edited Sat, 11 January 2025 at 11:09 AM
Can anyone tell me what the correct contents of the Python dir is?  I made a mess of the folder and now when I start poser I get the error:
"Can't open script for reading (PEPythonEngine::DoScript())"
PhilC ( ) posted Thu, 04 May 2006 at 7:26 PM · edited Thu, 04 May 2006 at 7:27 PM
Reinstall Obi-Wan it's your only hope :)
Seriously, reinstall Poser 6 followed by the latest service release.The Python library has over a thousand files in it so unles the Force is strong with you, you do not stand a chance.
Happy Star Wars Day by the way :)
muralist ( ) posted Thu, 04 May 2006 at 7:29 PM
Argh.  Alright.  Before I proceed -- Last year I went to the Python site and installed Python 2.4  I also have 2.1,  Do I need these?
PhilC ( ) posted Thu, 04 May 2006 at 7:46 PM
Poser comes with its own version of Python. You can install a seperate copy of Python if you like (I have), but it will be independant of and not required by Poser.
LostinSpaceman ( ) posted Thu, 04 May 2006 at 10:45 PM
Also, just to remind anyone trying to possible run pthon scripts who have multiple runtimes. All Python Scripts must be in the MAIN Poser runtime. If the script is in an external runtime, you'll get that error as well. (At least, that's what I was told!)
muralist ( ) posted Thu, 04 May 2006 at 10:51 PM
Thanks.  I deleted the old Python dir, then Installed P6 and the SR's, it all runs fine now.
