Fri, Jan 10, 6:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Material Problem
arrow1 ( ) posted Sun, 14 May 2006 at 11:30 PM · edited Wed, 08 January 2025 at 2:33 AM
Can aynone assist me with why the foot in the sand appears in the material room but doesn't show in the pose room or render? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
BeyondVR ( ) posted Sun, 14 May 2006 at 11:50 PM
I think you need to use a positive number in the displacement value, unless you want the footprint to be higher than the sand.  With a positive number, white will add thickness.  Can't give you a number, because it is one of those that depends on the measurement system you're using.
Playing with the value should give you something, unless the ground plane lacks enough detail in the first place.  Not sure if that makes a difference.
John
Medzinatar ( ) posted Mon, 15 May 2006 at 12:00 AM
You have to have displacement enabled in your render settings.  Since it a render effect only, you will not see it in the Pose Room. -Roni
