not many free shaders to be found
No, not if they are procedural...procedurals can't be transfered between apps....ANY of them.
3. To load them, if you mean by unzipping, put them in the C5P folder under presets-shaders & then whatever subfolder is appropriate. If you mean by loading as once in Carrara...just click on the preset button in the upper right....the one right underneath the sphere.
Yes, yes students of Carrara. Mastering the shader in Carrara will much power bring you. Yes, much power. This knowledge comes only by exploring the heart of the shader tree; Cannot be found in free shaders - only a dim shadow of it will you see. Immerse yourself you must. But to be truly free, mastering the sacred three must you: Modeling, lighting and texturing. Only then will you be one with your imagination. :-D
Here's one on making skin. http://www.shonner.com/drafts/carrara_skin_tutorial_a.htm
Thanks,
m
