Fri, Feb 7, 11:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 7:37 am)
Subject: Out of memory
Robert_Ripley ( ) posted Wed, 24 May 2006 at 5:46 AM · edited Mon, 27 January 2025 at 5:42 AM
I used 2 Files for saving, cause when poser is out of memory i can trash the saved file...
so i used x1 and x2...i saved x2 at last....worked on it..and then i want to save it on x1 again...but it failed...so x1 was damaged...so i cancled the save so i still got x2
now i can open the x2 file but i can´t work in it. Export is possible, the editor´s too...but you can´t see the main window.
Could someone test the file for me?
I saved it on Rapidshare, so you can download it easier and faster.
Here is the link:
http://rapidshare.de/files/21252229/WM20062.pz3.html
Inform me please if you could make it work again.
Thx anyway
Gora ( ) posted Wed, 24 May 2006 at 9:19 AM
I have the same issue constantly... wonder what causes it :(
Sorry I cant help, I work through a proxy server, and RS hates me....
"If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
Steven Wright
richardson ( ) posted Wed, 24 May 2006 at 4:45 PM
Edit>Generalr Prefs>Misc Are "Use binary morph targets" enabled?
Robert_Ripley ( ) posted Wed, 24 May 2006 at 5:20 PM
it´s enabled
ghelmer ( ) posted Wed, 24 May 2006 at 5:27 PM
disable it
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
Robert_Ripley ( ) posted Wed, 24 May 2006 at 5:32 PM
and then?
in the not working file?
richardson ( ) posted Wed, 24 May 2006 at 5:37 PM
mho but, binaries should be an advanced option. Not the default. These caused me severe losses when I got P6 running. I think you have missplaced a .pmd and all files that have this "figure" or .cr2(with missing pmd) will no longer work. This happens when you clean out a fat file sometimes and "binaries" were enabled. The downside is,, you'll need to open each figure one at a time and resave it to rid it of it's dependency of the pmd. I think you can kiss the PZ3, PZZ you had going goodbye. Upside is, it won't happen again. Once you uncheck "binaries" you'll need to "Set prefered state" and reboot to make it take effect.
