Create a single instance of your motion using keyframes. Open up the Advanced Motion Lab, and shift-click on name the object in question. A pop-up will appear, with one of the choices being "make repeat". I believe that if your movement sequence is shorter than the entire animation duration, it will just repeat the sequence for the rest of the duration. It uses all keyframes from the beginning of the animation to define the "repeating sequence". Or, you can make a sawtooth wave in the Advance Motion Lab, and stretch your keyframes out over the entire animation. The other way is easier.
Attached Link: http://shistudios.com
How can you apply this technique to the clouds? Since the sky isn't keyframed (or a selectable object), how can you loop sky animations????This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
How can I loop motion in Bryce? Or better yet...is there any way to copy a set of movements and paste them to the objects over and over again? What I need is a series of repetative movements for some objects...but all the movements need to be exact. Anyone???
