ah well, u see , v3 comes with free templates (see ;www.daz3d.com) and look for v3:'s templates:))
so u could make textures, or even buy ones with bruises:) some arent that expensive either:). then find a tut at daz too on skin texturing, :) hope this helps:)
Here are a couple of sources. The Battered and bruised for Victoria is for V2 but I had no probs using it on any figured with a little shifting :-)
Battered & Bruised For Victoria - Renderosity Market
Total Realisim Merchant Resource - Renderosity Market
Merchant Resource Kit1 - Cuts&Bruises - Poser Pros
In a world filled with causes for worry and
anxiety...
we need the peace of God standing guard over our hearts and
minds.
Jerry McCant
Here is one that I whipped up that is pretty universal, it uses a blending node so it can be placed on any texture The under skin is from a#DSK source that I have and the bruise is photoshoped. Since this uses a blending node then you can reposition / resize it as you like, jut be warned that across the cester is pretty hard because of Vik's seams. Also note, I HyperRealed the image before render. If you want realism you want HyperReal ... hay did I just do a comercial for FaceOff? :D
Transmap
Texture
Node
Attached Link: good as dead
there is also the "Good as dead" texture set at daz, which can be used on any unimesh figure, and has alot of different wounds.
http://www.daz3d.com/shop.php?op=itemdetails&item=3068
Rawn
Looking for a V3 skin texture with a bruise preferably on the back. Anyone know where I can find one or how to make one maybe? I downloaded something called UV Mapper but have no idea how it works... Thanks all
