Fri, Feb 7, 3:01 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Saving Sequenced Files Problem
Tom Thumb ( ) posted Wed, 07 June 2006 at 1:04 AM · edited Fri, 07 February 2025 at 12:16 PM
Hello all,
I render my animations in PhotoShop sequenced files  One of the many benefits of doing this is so in case of a failure, during rendering, I can continue from the last saved frame.
But here is my problem... I do a batch file for network rendering and say I have a sequence called "image" that has 200 frames and it only completes to frame 150. How do you continue saving after the failure so the sequence starts saving the file in the proper numbered sequence i.e. frame 151 to 200?
My try was to get it to start at the last saved sequence by moving the starting point of the slider to the frame you last rendered, but what happens is it does not save the file to the timeline frame count.... i.e. it saves frame 151 as "image000" instead of the desired output of  "image151".
Thanx!
TT
MarkBremmer ( ) posted Wed, 07 June 2006 at 10:03 AM
Hello TT, If you select the Options button underneath the File Format pull-down menu in the Render Room, you can set the Starting Frame number. A preview below the Starting Frame option provides a look at the sequence numbering prior to cliking OK. Mark
Tom Thumb ( ) posted Wed, 07 June 2006 at 1:49 PM
Thanx Mark,
I work with Lightwave and learning the different 3D platform conventions is taking its toll -heh
TT
MarkBremmer ( ) posted Wed, 07 June 2006 at 2:13 PM
Yes, it always kills brain cells - but in a good way. ;)
ghelmer ( ) posted Sun, 11 June 2006 at 12:18 PM
YAY!!!  Had the same prob (long time Max & Poser user) and came here to see if I could find help.....  BOOYAH!!!!  Here's this thread and my render's going again!!!  Sigh.....  ya gotta love 'Rosity!!!!!
Thanks Mark and Tom!!!!
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
