OK, Everybody pay attention:
The zip file contains EVERYTHING you need to install this file, except two things: RTE Encoder, and MAZ's Objaction Mover. Both these utilities can be found here in freestuff.
I repeat, everything you need is in the zip file, just LOOK for it. And Read the ReadMe.
David P. Hoadley
Okay I give up where in the sam hell is EVE4? I can't seem to find any reference to her any place but here.
Thanks,
Micheál
I'd like a copy, but I'd also like to know what Raunchminds is, and where. :)
Content Advisory! This message contains nudity, profanity
SoulTaker, I can't answer for individual tastes, for each is exclusively the property of its owner; however, her is a coparison of Vicky (left) and Evelyn (right). I personally think that Evelyn's figure is the more curvacious and better of the two (functioning genitals aside).
The question of Gintal figures as opposed to Non-genital figures is similar to a conversation I had years ago with my dad when it came to learning to drive, ie standard shift or automatic. I thought that automatic would be easier to learn, but my dad insisted on standard; why, so as not to limit my options.
You don't need to be either into porn or medical pics to want an anotomically correct figure, but if you do ever want to get into either, and NOT having one, can be a bummer.
David P. Hoadley
You'll find full explanation for using the RTE Encoder in the ReadMe.doc in the Evelyn file. As for Objaction mover, read the following:
Unzip the files.
-Bring up Object mover, and use the RuntimeGeometriesP4NudeWomanP4NudeWom.obj as the "seed file".
Use the Eve4.pcf as "Difference file"
Press the 'Convert' button, and perform the conversion.
This will give you the Eve 4.obj necessary, along with the blMilWom.obj, in decoding the Evelyn.rte file. The instructions for that are in the ReadMe.doc. Follow them precisely as written, and you shouldn't have any problems.
Yours truly,
David P. Hoadley
Do you have the EvelynE4,zip files, or do you need me to send them to you. If so, enmail me at: dph@013.net.il.
Yours truly,
David P. Hoadley
