This depends on the cloth. Some of the clothes have the major morphs of the figure implemented. Very seldom you'll find clothes that have themorphs implemented in a way that using the figures dials will morph the cloth too. You should check the morphs of the figure and the cloth, if they are similar, go to the parameter window of the figure, edit => copy and then to the parameter window of the cloth edit => paste. Usually it should work on the body, may be you have to do this for each and every bodypart.
Ulli
It's not an easy job to do as you've found out. Usually if I have a dynamic piece of clothing that fits with the picture I'm making I'll use that.
Most of the top clothing makers though put in the most often used morphs so it is just a case of dialling!
Some like Orion1167 will put in dials for specific characters, e.g. Fawne clothing has dials for gnd2 and Kielo and maybe a couple of more characters, I can't remember!
Injustice will be avenged.
Cofiwch Dryweryn.
Third-party apps like Wardrobe Wizard, The Tailor and Morph Manger(? There are new ones for morphs at Daz3D) and/or playing with magnets and doing what you did in trying to tweak the dials.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Hi everybody,
Jules53757, Thanks for teaching me the trick about copying dial values. I didn't know that.
dlfurman, I had a vague recollection that some of those utilities could do that. Any recomendations for which ones are easiest to use for a newbie?
Angelouscuitry, I had briefly looked at that thread, but I didn't realize it could do that also. Sounds like quite a tool.
Thanks!
Helmer
Hi,
Are there any simple ways to fit clothes to morphed characters? As an example, I tried to use Nekoja's Winter Clothes with Rhiannon's Meghan. It didn't look good. I tried playing around with some dials, but got nowhere. In the end I removed the body morphs and just used the head morphs.
Any suggestions?
Thanks!
Helmer
