Sun, Feb 16, 6:50 AM CST
Subject: Tardis Troubles
Byrdie ( ) posted Wed, 14 June 2006 at 10:23 PM · edited Mon, 03 February 2025 at 6:41 AM
I swear, Redfern's Tardis is giving me a headache from all the hair pulling I've been doing trying to get it to work. I loaded it up in P6, hit render and as you can see, something is definitely wrong. Thinking it was a Poser "hissy fit" over using a non-P6 item, as sometimes happens, I tried it again in P5. Same result, whether I use Firefly or the old P4 engine. Does anyone have a clue what's gone wrong? Right now I'm at my wit's end. :-(
Stegy ( ) posted Wed, 14 June 2006 at 10:47 PM
Just a guess - you can maybe try reversing the normals on whatever material group is for the sign.
Little_Dragon ( ) posted Thu, 15 June 2006 at 1:12 AM
Enable the Normals_Forward option on the Psi01 and Psi02 materials.
artbyphil ( ) posted Thu, 15 June 2006 at 3:57 AM
could it be something to do with the inside being much larger than the outside?
(sorry I couldent resist what the others said is probably more helpful) :biggrin:
mrsparky ( ) posted Thu, 15 June 2006 at 4:46 AM
hard to say from the picture - but If it's the top sign check the object color isn't set to black.
Byrdie ( ) posted Thu, 15 June 2006 at 11:18 AM
Already checked the color, changing it doesn't help. Will try flipping the normals & see what happens.
Hm, maybe I need a new sonic screwdriver ...  ;-)
