Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:11 pm)
hey silver! great picture!perhaps you can put a picture's back same like a"sky"(for example),you can made this in "terragen" or "vue d'esprit2 or3".you create it,register in ".bmp"an after you import it in poser same like a back picture. (excuse my english if is not very good, i'm "french"). see you more...
If she is waiting for the portcullis to lift, perhaps there could be a hint (dread or anticipation) of what might be on the other side? A very large monster's foot, for example, would lead the viewer into the implied story and create sympathy for her. Fog tendrils (with little glowing eyes?)should be quick to pop in the scene and would add atmosphere. Even a silhouette (of the man she is perhaps shadowing?)would give a bit more depth to the scene. It is interesting, and I like the low lighting and possibilities for further adventure. Carolly
Perhaps you should think about making her pose more "battle ready". Her stance suggests that there is nothing to be feared beyond those gates. I suggest that she stand a bit more with her knees bent, slightly hunched forward, like she's about to bolt after the gates lift. The sword position looks a little weird too. You normally would not be able to hold a sword at that angel comfortably. Try either angling it down a bit or bring it up more with the fore arm bent in front protectively. One last thing is that maybe there should be more texture in the haze or fog... sort of more of a swirling smoke effect. It's a great start. visualkinetics
Couple of suggestions: Maybe a sky with a moon? crescent perhaps? A hint of buildings or mountains in the background? And maybe adjust the lighting - use a couple of sources, I'd suggest a bluish one outside the gate, above the figures height, set to about 4 and a yellow one to the left of the camera, at a little above 'ground level', set to about 10. That should pop the contrast up a bit, while giving the effect of moonlight and fire. Nice figure and idea - will be interesting to see what happens to this image :) Lyrra
