Mon, Jan 27, 1:24 AM CST
Subject: M3 full body morphs not working
Lord_Lucan ( ) posted Fri, 16 June 2006 at 9:26 AM · edited Sun, 12 January 2025 at 8:19 PM
I have M3 and the head and morph packs (seperate) installed.
Now I can apply the morphs and apply them by clicking on each body part; however non of the full body morphs do anything, even though they are listed in the parameters dials window.
Anyone know why, and how to fix?
ps: I can only seem to find a combined head & body morphs product at DAZ - is this the same as the one I bought?
On a sidenote, I protect my most used Cookies, but the DAZ site seems to think I'm someone called 'Paul Fox'?!
Acadia ( ) posted Fri, 16 June 2006 at 9:32 AM
Yes, the combo morph pack is the same as what you have with the separate body/head packages.
As for applying the morphs and using them...
When you are turning the dials do you have the particular part of the body selected?
cryptojoe ( ) posted Fri, 16 June 2006 at 7:38 PM
When applying the full body morphs, what I do is to select a part of the figure, then at the top of the parameter dials, click the pull-down menu and select "BODY" to make sure you are not trying to apply the morph to a finger only.
As for your account at DAZ, if you are not the person they name, they have a place for you to click so you can correct the misidentification. Or, simply contact tech support and tell them about it.
Yank My Doodle, It's a Dandy!
SoCalRoberta ( ) posted Fri, 16 June 2006 at 9:35 PM
Once they show in the parameters dial window, are you setting them at 1 instead of 0?
Adavyss ( ) posted Sat, 17 June 2006 at 4:53 PM
There is a bug in M3 body injectors
They work only if your figure is the first to be loaded.
If you are using P6, first delete the default figure 1, then load M3 for M3 to become Figure 1
