Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Hey Mr Fixer ...your here too..
I dont know what "winding" means but i do know there are some great water mat avail. true the e- frontier site
Realy good complex water maps, use as a extra map with other water maps it can do realy good FX....
Even in Vue5 E ..and 5Easel can do only 30% of what V 5 I can do :}
Chris "who is stalking the fixer whoahahahaha .... ahum ... sorry.... i'll leave now ...by .... "
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
Ahh now i get it S shape river is a winding river ... Ok...
And the texture maps .. ill contact you by IM or msn private ... got something you need testing !! hehehe
Chris
Chris
Is this more a material question or a terrain one? If you want to have it easy, you can simply create two terrains for each side of the river one. By creating a grayscale in a paint program as starting point - for good parallel borders of the river you simply flip the image horizontally (for example). Then you use the ground as water plane and construct so your winding river. If you want to do it really in one piece it is a little more tricky. Again, create the grayscale in a paint programm, with the river simply black or darker gray as the rest of the image - this will give you a valley then. Then you must create a rather complex mixed material - basic idea is to make it altitude dependant. For the lowest parts the water you want to have, for the rest other materials that maybe as well need to be mixed - dependant what you want to achieve.
Try this link...it might help as its a video tute I created showing how to create a river and stuff.
Calling you V5I experts out there!
I want to make a winding river scene and I can't see how to do it, any ideas?
I think it might be something to do with using a double texture or something, not sure. Any help appreciated.
Thanx!!
Injustice will be avenged.
Cofiwch Dryweryn.
