Sat, Feb 8, 12:27 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Extending the number of frames with Python - how?
Ajax ( ) posted Wed, 21 June 2006 at 2:41 AM · edited Sun, 02 February 2025 at 12:46 AM
I'm writing a script that generates a 100 frame animaton, but it doesn't work if the scene has fewer than 100 keyframes.  Is there a Poser Python way to increase the number of keyframes if the scene doesn't have enough?
PhilC ( ) posted Wed, 21 June 2006 at 4:57 AM · edited Wed, 21 June 2006 at 5:07 AM
There is no Python command to add frames to a scene. So you have to use a little skullduggery. Use the LoadLibraryFigure command to load a cut down PZ3 file.
Tested it to increase or decrease total frame numbers. Worked both ways without Poser raising its "do you want to delete frames" message.
You could even embed the PZ3 into your script, have the numFrames as a variable and get the script to write the file prior to executing LoadLibraryFigure. Yes I know its not a figure but don't tell Poser that :)
Ajax ( ) posted Wed, 21 June 2006 at 5:20 PM
Thanks Phil.  That's very sneaky.  Should do the job nicely.
PhilC ( ) posted Wed, 21 June 2006 at 5:41 PM
hehe, yes sometimes you have to take Poser Python down a dark alley and give it a serious talking to :biggrin:
face_off ( ) posted Sat, 15 July 2006 at 12:09 AM
Phil - I've been trying to work out a way to do this for ages!  Thank you!
Creator of PoserPhysics
Creator of OctaneRender for Poser
Blog
Facebook
