Fri, Nov 8, 6:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 12:39 am)
Subject: XFrog plant
Trepz ( ) posted Wed, 28 June 2006 at 7:25 AM · edited Fri, 08 November 2024 at 6:26 AM
Hello all,Have an interesting question.I  want to make an XFrog plant "bend" so it lays across a flat surface like a climbing/creaping  ivy or vine,would Poser be the prog to add morph targets or whatever? If not,how is this possible elsewhere? Your time and help is very appreciated.
-T
"Many are willing to suffer for their art. Few are willing to learn to draw."
dphoadley ( ) posted Wed, 28 June 2006 at 7:40 AM
What's an XFrog plant, and what flat surface does it have to lay across.  Poser is a progarm for posing your object, but as for adding morph targets, that depends on the nature of the morphs, and ii what program they were originally developed.
Objects can be bent and warped in Poser by targeted magnets, but they require a certain level of skill to apply.  Look for Dr. Geeps recent Tutorials here in the forum, as they specifically address this issue.
Yours truly,
David P. Hoadley
xantor ( ) posted Wed, 28 June 2006 at 7:56 AM
You could add bones to the plant to make it bend but that is not really for beginners.
wheatpenny ( ) posted Wed, 28 June 2006 at 10:30 AM
Site Admin
You could export the plant as an .obj or a 3ds mesh, then load it into a modeling program and use a bend modifier to bend it.
@ dphoadley: an xfrog planyt is a plant made in an organic moodeling program called xfrog.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
dphoadley ( ) posted Wed, 28 June 2006 at 11:49 AM
"@ dphoadley: an xfrog planyt is a plant made in an organic moodeling program called xfrog."
Thanks manhunter, for some reason, I thught that it be a plant with froglike qualities, ala Venus Flytrap; or leaping and clinging qualities such as those of the Grape Vine.
David P. Hoadley
ranachronos ( ) posted Wed, 28 June 2006 at 12:13 PM
The simplest way would be to do it in xfrog. You can shape it any way you want, and then export it as an obj. Here's a quick dying plant I did rendered in Bryce.
