Tue, Nov 26, 10:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: From Bike Shorts to Garter Belt...
marcm ( ) posted Sun, 22 August 1999 at 3:40 AM ยท edited Tue, 26 November 2024 at 8:32 AM
This is ready to go, just need somewhere to put it. Does the Props Guild accept transparency maps if not I'll need someone to host this for me 223KB. Regards Marc..
Ikyoto ( ) posted Sun, 22 August 1999 at 7:40 AM
Ok, Now I HAVE to start posting my trans maps. Seeing that people actually want different TMs will give me a small way to contribute here.
anson ( ) posted Sun, 22 August 1999 at 7:50 AM
I'm sure you could file it under "textures", there is a new texture section at the guild that is starting to grow. Nice work!
Dr Zik ( ) posted Sun, 22 August 1999 at 9:34 AM
Hi Folks! Nice work, Marc! Now that you mention it, perhaps I can now post a question about transp maps. I used P4's transparency maps feature and Photoshop to create a transp map for a woman's briefs [I would say "panties" but there's children watching :-) ] using the biker shorts as the template. It works fine at first, but if I try to adjust the model to another post I get an error message--something about "texture map cannot be found or read." The end result is that any subsequent renders will only display the default bike shorts--the transp map will not render any more. In some cases, the female woman texture--default or custom--is disabled as well, and the figure will take on the texture of the bike shorts. I suspect it might be a memory issue (I can only allocate 60mb to P4 until I add more RAM), but I wonder if you are anyone else has encountered this as a bug. Peter (Dr Zik)
spawn111 ( ) posted Mon, 23 August 1999 at 5:53 AM
if it is space you need, just email me and you can post the whole package on one of mysites! Rob
marcm ( ) posted Mon, 23 August 1999 at 6:51 AM
Thanks Peter No I don't have the same problem that your having, It sounds memory related, but I'm no expert. Now thanks for the offer rob the texture is up in the Fun Stuff section. In the future I'll probably post the items at the guild.
