Make a folder called "Poser runtimes" I keep mine in the Curious Labs folder but it could even be on another drive. Make a seperate folder for each runtime you want, like "Michael 3", "Mill kids" and so on. Then dump your files into each folder so that there is a runtime in each folder. Open Poser 6. Go to figures, then hit the up arrow that shows the runtime you are in and the downloads folder. Go to the bottom and click on the plus (+) sign. Navigate to the folder where you put your extra runtimes and click on the name of the folder with the runtime you want to add - not "runtime" itself. It will now appear in your base P6 directory and you can switch back and forth between runtimes. Very helpful and Poser will run faster without dumping everything into the main runtime. Good luck.
Hi curtskinn,
I have reposted the "Runtimes" tutorial.
You can find it in the Maroon Theater.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I currently have booth poser 5 & 6 on my pc, but want to uninstall poser 5, but don't want to lose the runtime stuff from poser 5. How do I add a new runtime to poser 6 so I get all of the poser 5 runtime?
