Thu, Jan 30, 9:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: 2 quick prop questions - (question for propmakers)
pakled ( ) posted Tue, 04 July 2006 at 12:13 PM · edited Thu, 30 January 2025 at 8:57 AM
Ok, I've created a Morion (and a Moron) helmet, and created a  texture for it. It works. (It's the 'Conquistador-type' helmet, and I made it for Mike 3). Now, I need to figure the next 2 steps
Getting it in as a prop, then 'tying' the texture to the object. I think you bring the object in, then save it as a prop. This creates the prop as a prop file, just need to know if that's right. and how to do that..;)
The texture (a jpg file) is being asked for, as in 'it's missing'. Most props have something in it that directs the prop, character, etc, to reference a specific location. Is this an entry in the .obj file, or some setting?
Once that's figured out, I'll be happy to offer it as a freebie (the original helmet is at Traugs, I'll just let Peejay know a better one is on it's way..;)
Inquiring minds want to know..
BeyondVR ( ) posted Tue, 04 July 2006 at 1:14 PM
Go to File--Import Object--Wavefront OBJ.  In the dialog that comes up, leave everything checked and type in a percentage of figure height for the prop.  Position and scale it to fit Mike's head.
Now, if you want the prop not to show the scaling, but come in next time as 100%, export the prop as OBJ, checking top option in that dialog.  Leave others checked.  Delete your original and import the new one.  This time, UNCHECK all boxes on the import dialog.  The hat will appear just where you had it.
One more thing to check is the center point.  If it's off, the hat will rotate around a point in space instead of itself.  With it selected, open the Joint Editor.  A green cross should appear somewhere on the screen.  If not visible, type in 0.000 in all the Center Point locations (X,Y &Z), and pick it up off the floor.  Use two ortho views to place it, then close the JE.
Be sure to parent it to Mike's head.  Apply the texture in the MAT room, and then save it to the library as a smart prop.
John
pakled ( ) posted Tue, 04 July 2006 at 1:21 PM
thanks..but I have Poser 4..sorry, shoulda mentioned that..;)  All the rest looks very helpful..off to try it..
BeyondVR ( ) posted Tue, 04 July 2006 at 1:37 PM
You're welcome!
The only difference is that you would go to Render--Materials to apply the maps.  Everything else is same as P4.
John
nomuse ( ) posted Tue, 04 July 2006 at 3:23 PM
Nicely put, Beyond. I'm surprised more people don't do the import-scale-export routine. It is so fast and makes for an easier .obj to work with later. It's also a great tool for lumping several things together into one object, or even adding a new detail or even a new part onto an existing figure. For extra points; once you have re-imported the .obj, done the final adjustment, set the textures and material values, and saved it as a smart prop, open the .pp2 again (with an outside text editor) and re-direct it to refer to the outside .obj file. Create a folder set for prop, geometry, and texture, and with that same text editor make sure that all the file references have the full file path in them (aka Runtime:textures:my_textures:my_new_helmet.jpg) It takes a bit to get used to the inside of a .pp2 It took me a few months to get comfortable inside those Poser files ( I use an ordinary text editor like BBedit for mine.) But once you've cracked the code, it makes it possible to check and change file paths, delete body parts, add ERC channels, build easy-pose dials, and so forth.
BeyondVR ( ) posted Tue, 04 July 2006 at 4:15 PM
Good point, nomuse!  I used to have a tut on doing just that (external OBJ).  There are now utilities to do that, so I took it down.  Think it's still relevent?
John
nomuse ( ) posted Tue, 04 July 2006 at 5:08 PM
Yah. Esp since not everyone is on PC.
BeyondVR ( ) posted Wed, 05 July 2006 at 12:31 AM
Heck, I hadn't even considered that.  Just got done updating a few Bryce tuts, and don't have any Poser up right now at all :(
I'll put that one on the list.
John
pakled ( ) posted Wed, 05 July 2006 at 10:34 AM
Thanks..hmmm...I was trying to avoid editing the files (until I know what I'm doing), but this is enough to get started with. Thanks for everything...I'll see what I can do with this.
