Thu, Jan 23, 6:27 AM CST
Subject: Looking for a Prop and Tutorial
Niles ( ) posted Sat, 08 July 2006 at 8:48 AM · edited Sat, 18 January 2025 at 5:09 AM
I need a tennis court with net, also need the tutorial for Z-toon... think that is what it is called. You flatten the image by using the z-scale.   Thanks Niles
thedoctor ( ) posted Sat, 08 July 2006 at 9:34 AM
Don't know if you need it bad enough to spend $29, but TurboSquid has a 3D tennis court with net that comes in OBJ format which will import into Poser:
http://www.turbosquid.com/FullPreview/Index.cfm/ID/242084
If you want to keep the price to free you can e-mail me and I have a court without a net I whipped up. You could make a net easily by using the plane primitive in poser and simply map a net with a transparency map onto it. You can get good tennis net textures by searching for "tennis net" using either Google or Yahoo image search.
If you want it write me at vislaw@yahoo.com.
Miss Nancy ( ) posted Sat, 08 July 2006 at 2:28 PM · edited Sat, 08 July 2006 at 2:36 PM
I Lost the link to snowsultan's z-toon thing I thought it was in the backroom/tutorials section of this forum, but no luck. basically you parent everything to an invisible box, then flatten the box in the z-direction.
Niles ( ) posted Tue, 11 July 2006 at 4:57 PM
Thanks, to all.
The liks here at Rendo did not work... at least for me. SnowSultan sent me a workinfg link, it is DAZ3d.com.
                     Niles
