Thu, Jan 23, 11:10 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Beam of Light
ghoyle1 ( ) posted Mon, 10 July 2006 at 11:46 PM · edited Thu, 23 January 2025 at 2:14 PM
Hi there,
I'm doing a simple render of a lighthouse for a friend, just a lighthouse and a beam of light against a plain black background. The hardest part is getting a decent looking beam of light. I'm playing around with a cone prop and various transparency settings and shaders, but I'm not really satisfied yet. Any cluse as to how I can make just a simple beam of light?
Thanks,
Guy
markschum ( ) posted Tue, 11 July 2006 at 1:14 AM
If you have a background you can use a spotlight set as a volumetric light and set the atmosphere to show the cone of light.
Set the atmosphere material in the material room to 'volume on'  and set atmosphere dial on light to 1, light intensity try 300%.
Then change your settings to get the right effect.
You must have an object in the background for the light effect to show.
thefixer ( ) posted Tue, 11 July 2006 at 2:43 AM
Yep, That's how I would do it.
You can also adjust the beam angle and start and stop points to get a realistic effect!
Injustice will be avenged.
Cofiwch Dryweryn.
ghoyle1 ( ) posted Tue, 11 July 2006 at 6:30 AM
That's excellent! I hadn't thought of an actual spotlight. I'll try this right away. Thanks!
Guy
ghoyle1 ( ) posted Tue, 11 July 2006 at 8:28 AM
I've placed the spotlight at the top of the lighthouse, and have got the beam visible now, but it starts out weak and gets brighter as gets farther away from the lighthouse. Of course, it should be stronger nearer the lighthouse and weaker as it gets farther away; what should I change to get this effect?
Thanks again
Guy
Tyger_purr ( ) posted Tue, 11 July 2006 at 8:42 AM
Quote - I've placed the spotlight at the top of the lighthouse, and have got the beam visible now, but it starts out weak and gets brighter as gets farther away from the lighthouse. Of course, it should be stronger nearer the lighthouse and weaker as it gets farther away; what should I change to get this effect?
Thanks again
Guy
In your spot light parameters:
Dist Start = distance from the light at which it begins getting weaker
Dist End = distance from the light which the light is no longer visable. if set to 0 it will never end.
My Homepage - Free stuff and Galleries
