Youre not really out of memory , either the obj file isnt where its supposed to be or the.rsr file is corrupt. Check your geometries folder , if the object is in the right place, then you need to delete the .rsr file that has the same name as the object. Then when you try to load that model again it will build a new .rsr file.
Hi all, I have a question that is frustrating me to no end. I have a hair texture that is giving me fits.I downloaded a hair zip file " strip-hair" and did as the Readme said. It read "just exract the zip directly to your Poser.exe file and Poser will put it in the right spots." well it did just that now here is the kicker. I will go to add this on a model and when I click on it a screen comes up saying " cannot open resource file Runtimegeohairnewstrip_hair.obj" Then when I click ok it then tells me to save my work soon you are out of Memory. Just how much memory does poser require? I've got almomst 300megs of ram? Or is this another problem? Seal
My Facebook Page
