Mon, Jan 13, 4:05 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Clothing MorphKit by Netherworks, does it really work?
Chippsyann ( ) posted Thu, 13 July 2006 at 11:47 AM · edited Sat, 11 January 2025 at 1:33 PM
Has anybody tried, “Clothing MorphKit for Victoria 3 by Netherworks” and is it an easy product to use? The write-up on it sounds great but, I’ve learned through “buy and try” that products sometimes don’t work as easy as they claim.
Is there someone out there that can add some truth to this item?
thefixer ( ) posted Thu, 13 July 2006 at 12:13 PM
I asked a question in the forum a couple of weeks back about how I could put morphs into clothing easily!
I had dialed a body shape for V3 and found none of the clothing items I had would fit because the breast size was wrong or some other parameter was wrong.
Anyway someone recommended this item by Netherworks, can't remember who, so I bought it and used it within probably 5 minutes and it added the morphs I needed into the clothing item I wanted to use.
So the short answer is Yes it worked for me as advertised!
Injustice will be avenged.
Cofiwch Dryweryn.
jonnybode ( ) posted Thu, 13 July 2006 at 12:23 PM
Hi!
I have bought the product and like it very much, if you read the manual youll do just fine.
Netherworks does some excellent stuff  and i wouldnt hesitate to buy  from them again.
Regards / Jonny
Chippsyann ( ) posted Thu, 13 July 2006 at 12:27 PM
Thanks for the info, you came through right on time.
rty ( ) posted Mon, 17 July 2006 at 12:16 PM
Great kits, the V3 and the A3 ones.
No problem anymore buying clothes without morphs.
darken666 ( ) posted Mon, 17 July 2006 at 1:31 PM
I've got the A3 kit and it's simply awesome.  I've gotten far more milage out of clothing sets since I can fit them to my morphed characters now.  Like any other fitting solution, one might need to make some small tweaks  but it's easy to just grab the right magnet and shift it a little,  And I've not had the crunching problem that some other fitting tools have problems with.
4blueyes ( ) posted Mon, 17 July 2006 at 2:06 PM
Netherworks MorphKits are awesome and very easy to work with :) Michal 4blueyes
