Fri, Jan 10, 8:00 AM CST
Subject: Wardrobe Wizard and Millenium Teeth
mathman ( ) posted Wed, 19 July 2006 at 5:58 AM ยท edited Wed, 04 September 2024 at 3:44 PM
Hi all,
I am just wondering if anyone has had success with transferring the Millenium teeth to Mil3 or even non-DAZ characters using the Wardrobe Wizard ? ..... or maybe even some other means ?
Interested to know, and how well did it work ?
regards,
Andrew
PhilC ( ) posted Wed, 19 July 2006 at 6:16 AM
Since it is fine detail and inside the model I doubt if they would convert very well. A far better solution would be to import the OBJ, scale and reposition.
mathman ( ) posted Wed, 19 July 2006 at 6:29 AM
Thanks, Phil .....
but would importing the OBJ allow you to apply MAT poses ? ..... or would it even bring in the default textures ?
PhilC ( ) posted Wed, 19 July 2006 at 6:36 AM
Quick answer ----- try it and see :)
Long answer ----
I do not have the teeth so I don't know if they are a figure or a prop (props?). Load the teeth into the scene. Go to the material room and save the materials as a material set. You'll then be able to apply this material set to the imported/scaled teeth.
mathman ( ) posted Wed, 19 July 2006 at 7:03 AM
OK I will try that, Phil. Thanks.
rreynolds ( ) posted Wed, 19 July 2006 at 8:49 AM
The Mil3 figures all have MilTeeth.
mathman ( ) posted Wed, 19 July 2006 at 9:02 AM
Sorry, rreynolds, I don't get your point ?
rreynolds ( ) posted Thu, 20 July 2006 at 9:42 AM
I was answering the first half of your question that there is no reason to transfer MilTeeth to any of the Mil3 figures because all those figures already have the teeth.
For any other figures, your best bet is resizing and parenting the teeth figure to the character's head. That allows retaning the figure as a character that can be posed separately from the figure's mouth. Using an Obj prop will leave the teeth stuck in whatever posed you saved it as. If the character, you're putting the teeth into, has a separate jointed jaw, versus mouth morphs to open and close the mouth, saving the top half of the teeth, and bottom half, separately, allows parenting the upper to the head and the lower to the jaw.
mathman ( ) posted Thu, 20 July 2006 at 5:28 PM
OK thanks rreynolds, I will look into that. Sounds complicated.
