Thu, Nov 14, 6:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Can`t handle BVH-Motions
factor ( ) posted Sat, 22 July 2006 at 3:15 AM · edited Thu, 14 November 2024 at 6:51 PM
Hi!
Its horrible!!!!!!
Its my first time with Motions. So i browse to my BVH-Motions and here the problem begins:
Poser asks something about "aline to the x or Z-Axis", next step it asks if it shoud tweak something or not. (I can`t remember the exact phraze right now).
But.... WHATEVER i tried in several combinations.... i get 2 important errors.
One: V3 is kicked up high in the air!
Two: she looks like a freak with knots in arms,legs and body!
I am at the end of ideas! And frustrated as well.
Does anybody know a good tutorial to LEARN using BVH-Motions?
Or has someone a hint what i can do?
Many, many thanks, Factor
Dale B ( ) posted Sat, 22 July 2006 at 6:19 AM
Quote - Hi!
Its horrible!!!!!!
To answer your second question, the two messages should be answered 'align along the X axis', and 'scale automatically'. The first provides the basic orientation so the app knows how to look at the motion data referring to one axis, and the second one scales the spatial information in the bvh file to match the figure you are loading it onto. Vicki going vertical is easily fixed. Select the hip, then click on the Ytrans dial. Go to the menu bar and select 'window', then 'graph' from the drop down menu. The graph editor is going to be your best friend in animation, as it makes it easier to find and fix keyframe problems. Anyway, oyu should be looking at a graph of the y translation values (assuming she isn't jumping about, it should be a fairly straight line). Move the graph to one side, so you can see better. Make sure you are on frame 0001, then go back to the menu bar and choose 'figure', then drop to floor (or simply hit control D). The figure should return to floor level for frame one, then jump right back up again for the rest of the animation. In the graph editor, you'll see that, with the first keyframe much lower , and a sharp line leading from that frame 01 keyframe to the next one. Place your mouse pointer between those two keyframes, press and hold left click, then drag the pointer to the right to the end of the animation. The window should turn black with white lines. Release the left button and move the slider below the window so you can see the difference between that first frame and the rest. If you move the pointer into the black area, it will turn into a parallel horizontal line. Press and hold ctrl, and it should turn into a parallel vertical lines. Simply press and hold left click, and drag your mouse downward slowly. The entire selected section should move vertically, until you have it in line with the 01 keyframe. Once you're satisifed, release the left click and close the editor. Vickie should have her feet firmly on the floor for the entire animation now. The broken joints are even easier. =Before= you load the bvh file, go to 'figure' on the menu bar and turn of IK for all the limbs. If that doesn't fix it, then there is some basic difference between the armature the bvh was made/extracted from, and Vickies rigging system. Fixing that is going to be a matter of frame by frame, value by value tweaking. And get used to the process; motion files of any kind require tweaing, sometimes major tweaking.....
factor ( ) posted Sat, 22 July 2006 at 6:42 AM
B.I.G. Thanks, DALE!
THIS was really a kind of Tutorial i`ve looked for!
You helped a LOT!
Even if my english isnt that good.... i`ll print this out... and work like your atvise.
Thanks again
Factor
Dale B ( ) posted Sat, 22 July 2006 at 6:43 PM
You're welcome! Plan on asking a lot of questions here and elsewhere; the manual isn't the clearest on some things, and there are tricks and techniques that simply aren't in there. You might want to check out Dr. Geep's tutorials; the Doc gives a rundown through the various versions of Poser from 4 on, and provides a lot of starting information on things like dynamic hair and cloth, animation, and so on and so forth....
factor ( ) posted Sun, 23 July 2006 at 2:34 AM
Hello Dale again....
Even if  THIS question has nothing to do with BVH-Motion.... i don`t wanted to open a new thread.
I have a large arrangement with 6 Characters and a BIG hall theryre in. Poser 6 cant handle this to render with shadows, raytracing (i have reflective walls n floor)....
I`ve read somewhere that you can render in batches.... mean: first the scene without shadows.... then ONLY the shadows, and so on.
Do YOU have an exact plan which "formula" is the best to do so? I only know that its important to save those pieces in PNG because of the layers.
I`ve searched all over the forum... but didnt found anything. Maybe my search-term wasnt that good. Also i didnt found a Tut.
Thanks in advance, Factor
Dale B ( ) posted Mon, 24 July 2006 at 6:22 AM
On this matter, I'm afraid not. With the kinds of animations I like, I do my figure animating in Poser, then import it into Vue Infinite for rendering (Infinite has a network rendering system built in, and Esprit has the Mover module to give it the same abilities). The shader system that Poser uses doesn't translate over to VI (and this is common; each renderer does things a little differently, and some translations are practically impossible), but David Burdick wrote SkinVue a little while back, which is a Python script that either totally exchanges Vue shaders for Poser skin textures, or enhances that skin texture. If you want to see why I do this, hop over to belino.net, homepage of Phoul, the acknowledged master of Vue movies, and look through the offerings he has up. The teaser for Vue 6I is just that; you can get the showreel for Vue 5 I either at his site, or eon's website. I'd ask someone with lots more experience with the Poser renderer; having multiple reflective surfaces renders all the ideas I would use unworkable.....
