Mon, Nov 25, 9:14 AM CST
Subject: Poser 6 & PNGs
chud ( ) posted Sun, 16 July 2006 at 3:58 PM · edited Mon, 25 November 2024 at 8:34 AM
Is there a way to keep Poser 6 from generating pngs for each file? I don't want P6 to generate pngs. I've used ThumbNailer to embed pngs in Poser files and I've chucked the pngs. I just don't want them or need them anymore. I'm running OS 10.3.9.
PhilC ( ) posted Sun, 16 July 2006 at 4:19 PM
If you make your PNG's read only they will not get over written but there is nothing to stop Poser from creating the file. If it can not over write what is there it will name the file "your-file1.png", your-file2.png" etc. Your thumbnail will be safe but the directory will fill with unwanted files.
chud ( ) posted Tue, 18 July 2006 at 2:08 AM
Thanks, Phil. That's a drag.
chud ( ) posted Fri, 28 July 2006 at 2:52 AM
Just to flog a dead horse, I emailed e frontier and this is what they said: (Not that I didn't believe ya Phil) "Unfortunately there just isn't any way to keep Poser from generating PNG previews when you add items to the library. You can always go back and replace 'em- I do that all the time, using rendered images and Photoshop composites- but you can't keep Poser from writing them in the first place. Might be simpler to write an Applescript that searches through specified library folders and pulls out all the PNGs it finds, and run it periodically." Poser 4 didn't generate pngs like Poser 6 does. Wonder why...
Dizzi ( ) posted Fri, 28 July 2006 at 8:40 AM · edited Fri, 28 July 2006 at 8:41 AM
Quote - Poser 4 didn't generate pngs like Poser 6 does. Wonder why...
Because it didn't use PNGs ;-). But editing PNGs is easier than editing RSRs, so it's a change for good.
