Sat, Jan 11, 8:58 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Want to set non zero parameter dial vaules to a color
ceba ( ) posted Thu, 03 August 2006 at 7:53 PM · edited Sat, 11 January 2025 at 5:53 AM
instead of the standard (on my sys) white, so they standout.  But I can not find any refererence to a settextcolor type paramater for python.  does anyone have any ideas...
Thanks...
PhilC ( ) posted Thu, 03 August 2006 at 8:12 PM
Don't take this as definitive but try looking in  runtime:ui:parmDialPrefs.xml for :-
 Widget name = "name" -------------- textCloor= "-16777216"
ceba ( ) posted Thu, 03 August 2006 at 8:53 PM
Thanks PhilC, can't figure out if those will work via python (yet) but some neat stuff.  Maybe I'll make my dial background BRIGHT RED.  had no idea this and the psd files were there...
Again thanks for your help.
nruddock ( ) posted Fri, 04 August 2006 at 1:36 PM
You can't alter Poser's UI colours via Python.
If you do modify the XML files, all the dials will be the same colour.
