Tue, Feb 25, 10:37 AM CST
Forum Moderators: RedPhantom
Subject: shrinking/squeezed background
dawnryder ( ) posted Mon, 07 August 2006 at 3:29 PM · edited Tue, 25 February 2025 at 10:28 AM
hi there everyone i'm doing a piece with a landscape photograph imported as a background. i've carefully positioned my characters so far so good but when i render the photo for some reason gets squeezed into an almost square shape, it only shrinks in width - the height stays the same., leaving a wide white margin down the sides where photo was, the character doesn't get squeezed anybody know what i'm doing wrong?
diolma ( ) posted Mon, 07 August 2006 at 4:50 PM
Either:
Set your preview/render image size to be the same ratio as the imported photo, or
Use a 1-sided square  (proportioned to your photo's size) and apply the photo to that. Once the square has the corret proportions, you can then move it back in the Z axis (so it doesn't interfere with any other props in the scene) and use scale to size it properly (turn off "casts/receives shadows") for the square, and plug the photo into the AMBIENT node for the square. Make diffuse black)...
The latter is my preferred approach (but doesn't always work). OTOH, loading a background image always seem to cause more problems the it's worth...
Just my humble opinion..
Cheers,
Diolma
Fazzel ( ) posted Mon, 07 August 2006 at 7:27 PM
You didn't say, but if you have Poser 6 there is an even easier way.
Just  go to the material room.  If you are not that familiar with the
material room there is a box that says Simple/Advanced.
Click on Advanced.  Then click on the background of your scene
Then find a box labled BG Picture and  then put a check in Auto_Fit
of the BG picture box. Problem solved.
pakled ( ) posted Mon, 07 August 2006 at 7:40 PM
is there a way to break the aspect ratio? it can be done in other programs.
Victoria_Lee ( ) posted Mon, 07 August 2006 at 8:25 PM
The auto-fit option will fit the background picture to the render window size, regardless of the aspect ratio, pakled.  That's one of the reasons this is a nice fix.
Hugz from Phoenix, USA
Victoria
dawnryder ( ) posted Tue, 08 August 2006 at 9:43 AM
oooh thanks for your answers I do have poser 6, so it looks like it's an easy fix and i'm quite familiar with using nodes (but clearly no expert) this never happened in poser 5 but i do like using background photos for my skies many thanks again dawn
pakled ( ) posted Tue, 08 August 2006 at 10:26 AM
we are not smart..;) s'ok..as long as you got an answer..
dawnryder ( ) posted Wed, 09 August 2006 at 2:29 PM
it wasn't as easy as it sounded i checked the nodes and the background was already on autofit i tried taking the background off and putting it back in but that didn't work i put a 'square' primative in and made it to measure - but that turned out all fuzzy - perhaps i should have used the hi res square? i've given up for now i'll have another go in a few days thanks again x
raven ( ) posted Thu, 10 August 2006 at 1:53 PM
As well as having Auto fit selected, make sure your maximum texture resolution in your render settings is larger than the size of the background you want to use. That should sort it out.
