Mon, Dec 23, 7:08 AM CST
Subject: Materials in imported ..OBJ's: please forward to whoever writes Bryce
Anthony Appleyard ( ) posted Sat, 14 April 2001 at 5:30 AM · edited Sat, 03 August 2024 at 11:09 AM
I made an .OBJ object (a breathing set) divided into groups and materials. The materials are not the same as the groups. WHen I imported it into my Bryce 4, Bryce 4 dropped the material names and used numbers instead. That is pestiferous. E.g. its pressure gauge contained 3 circular materials, nearly coincident: back, dial, glass, and in Bryce I had to select the glass to make it transparent. And it was the devil's own job isolating the glass, because ctrl-leftclick only showed in the menu several entries "prgauge and a number".
Phantast ( ) posted Thu, 19 April 2001 at 5:07 AM
Grouper will fix exactly this problem for you. http://www.chesco.com/%7Ecjcigas/tutorial/grouper/index.html
