Fri, Nov 22, 4:23 AM CST
Subject: 3d city generator, link inside
draculaz ( ) posted Thu, 17 August 2006 at 6:37 PM · edited Fri, 22 November 2024 at 4:23 AM
http://www.cs.tau.ac.il/~tommer/citygen/
city generator. i kid you not. check it out!
pakled ( ) posted Thu, 17 August 2006 at 6:42 PM
interesting, now if I only knew something about XML (I thought it was clothes sizes or somethin'..;)
ellocolobo ( ) posted Thu, 17 August 2006 at 10:24 PM
Drac> Very good find and it works so easy...For those who don't know..It saves as .wrl files which are very easy to convert..
martial ( ) posted Sat, 19 August 2006 at 5:48 PM
Online Now!
Seems nice Here in Vue using sample XML.Where can i find to write this XML script?Thanks
attileus ( ) posted Sun, 20 August 2006 at 11:52 AM · edited Sun, 20 August 2006 at 12:00 PM
Impossible to import it to Bryce 5.01; otherwise it looks pretty good inside CityGen; now they have to implement an export function featuring hundreds of common formats... :-)  (dxf, obj, 3ds and so on)
Hm, it worked fine with Vue...
ellocolobo ( ) posted Sun, 20 August 2006 at 1:50 PM
attileus> It imports fine into Bryce but you must convert it from .wrl 2.0 to 3ds or some other type of file..Bryce only imports .wrl 1.0...
FranOnTheEdge ( ) posted Wed, 23 August 2006 at 1:02 PM
Sounds nice from what you guys are saying here, but I didn't understand what the guy was saying on the download site.
Is there an instruction file somewhere?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
FranOnTheEdge ( ) posted Wed, 23 August 2006 at 1:53 PM
Quote - For those who don't know..It saves as .wrl files which are very easy to convert..
How?
Fran's Freestuff
ellocolobo ( ) posted Wed, 23 August 2006 at 5:39 PM
Fran> What do you use to convert files?
2zuluone ( ) posted Wed, 23 August 2006 at 8:26 PM
Yo ellocolobo, You might want to look at: 3D Object Converter v3.80 3D Object Converter is a powerful 3d model translation and interactive viewing shareware tool that allows arbitrary 3d model data to be imported from external sources, exported to various industry standard 3d file formats with great accuracy and quality. The program supports 440 file formats. It is available for Windows95/98/Me/NT/2K/XP.
ellocolobo ( ) posted Wed, 23 August 2006 at 10:06 PM
Zzuluone>  Thanks for the answer but I already have it..My question was ment to help Fran convert .wrl file..I wondered what she uses now to convert her files..Thanks again
AgentSmith ( ) posted Sat, 26 August 2006 at 1:45 AM
Couldn't get any of the CityGen's .wrl's to open with 3D Object Converter v3.80.  ;o(
draculaz ( ) posted Sat, 26 August 2006 at 3:00 AM
i don't have bryce installed after the last format so i can't exactly help out. but there has to be a way
m
AgentSmith ( ) posted Sat, 26 August 2006 at 4:25 AM
Tried Blender and Carrara. No go on importing the wrl's.
ellocolobo ( ) posted Sat, 26 August 2006 at 11:24 AM
AccuTrans will open it right up...
deadman67 ( ) posted Sat, 26 August 2006 at 2:30 PM
were do we find AccuTrans thanks
deadman67 ( ) posted Sat, 26 August 2006 at 2:36 PM
never mind i found it
ellocolobo ( ) posted Sat, 26 August 2006 at 2:51 PM
You can also use Deep Exploration and Explorer 3d....
FranOnTheEdge ( ) posted Sun, 27 August 2006 at 4:19 AM
Quote - Fran> What do you use to convert files?
I don't.  I don't think I've ever had to convert anything.  Which of course, is precisely why I was asking.
But no matter, Tommer tells me that Blender can convert his files - this is handy since I'm currently trying to learn Blender.
Fran's Freestuff
serendigity59@gmail.com ( ) posted Sun, 27 August 2006 at 8:31 PM
There is a very quick and easy way to generate any number of interesting cityscapes using any photo editing or graphics program on any operating system, which is not processor hungry. Here is how:
We are going to make a bump map to use in Bryce.
First, create a square canvas, say 800x800 pixels, and color it black.
Second, create a whole lot of squares, rectangles, ovals, circles etc using DIFFERING shades of grey of differing sizes. Imagine you are looking straight down on the city grid from the air. See the attached example. If you seek street grids, make sure you leave black spaces for these in your layout. Save the image as a TIFF or good quality JPG.
Third, open Bryce, create a terrain, click E to edit the terrain. Then click the Pictures tab in the Editing Tools window. Load the image you just made and click Apply.
You now have a terrain which consists of a whole cityscape full of building like structures of varying sizes and heights. You can play with some of the Elevation settings to vary the height and appearance, some smoothing is recommended to create more rounded edges etc.
Click the tick to save the terrain back into the main Bryce window. Position into your scene, apply some kind of convincing city texture to the terrain, add atmosphere, sky, and even some ground lighting, and there you have it.
Adjusting the height of the terrain in edit mode changes from Manhattan style to country town.
Obviously not a replacement for more sophisticated modeling and texturing of individual buildings, but it can look surprisingly good as a distant city, or a city from the air viewed at an oblique angle.
Best of all, the terrain is reasonable fast to render, although applying a complex texture to the terrain with reflectivity and or metallic properties will substantially increase the render time. I will post an example city scape created in this way onto my gallery page here for you to see.
I hope this helps out newbies, or even experienced Bryce users who have never considered this instant Metropolis method before. Please feel free to save the enclosed city bump map to get you going if you would like to.
See example images here:
http://www.renderosity.com/mod/gallery/index.php?image_id=1280792
serendigity59@gmail.com ( ) posted Wed, 30 August 2006 at 5:15 PM
Here is another render using this bump map for a city...
