Thu, Jan 30, 10:41 AM CST
Subject: Making cloear sea water look good in Vue.
starbase1 ( ) posted Sun, 27 August 2006 at 3:02 AM · edited Wed, 29 January 2025 at 9:00 PM
Hi All, I am trying to get to grips with Vue, and thought I would try and recreate something I used to like doing in good (very) old Vistapro. A flight past a lot of islands.
I'm getting to grips with the animation system which is not too bad at all, (though at the moment I seem to be creating stray key frames a lot!), but I am having big problems with the water.
I'm trying the presets, I'm trying tinkering with the presets. But all I get is a sort of glassy look.
The big problems are the razor sharp shore, and the transparency - I can't seem to get that 'fading at shallow depths' look that terragen can do so well.
Any clues? I've attached a picture.
Thanks,
Nick
schoesser ( ) posted Sun, 27 August 2006 at 6:24 AM
hi, you can change the water with the function editor.. there are functions for watereffects. with the materialroom you can change the material and other options for your water.
jc ( ) posted Sun, 27 August 2006 at 12:48 PM · edited Sun, 27 August 2006 at 12:49 PM
Schoesser is correct, probably the water material parameter you want most to change is the "Becomes reflective at angle..:" on the 'Reflection' tab. On the 'Transparency' tab there is often a slider (maybe depending on which water material you choose) for "Murky Vs Clear".
People have created functions for changing the water to white at beaches or rocks, by creating a function driven by the distance to the ground under the water. Look for tutorials on "shoreline", "seashore", "function editor", etc.
Monsoon (mod of Vue forum at 3D Commune) sells a nice kit called SeaVue with lots of materials for white water, breakers on sand, white-capped waves, etc. He has several tutorials and cool freebies as well. I love his 'Ecowear' foreground ecosystems for land as well.
Check out my directory of Vue tutorials all over the web (please add suggestions when you find new ones).
 _jc  'Art Head Start' e-book: Learn digital art skills $19.95
'Art Head Start.com Free chapter, Vue tutorials, models, Web Tutorials Directory.
starbase1 ( ) posted Sun, 27 August 2006 at 2:57 PM
Thanks for the tips guys, much appreciated.
