Wed, Nov 13, 12:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Why is Poser 6 always rendering at 72dpi , I want 300
RodB ( ) posted Tue, 29 August 2006 at 6:20 PM · edited Tue, 12 November 2024 at 7:41 PM
Change the setting in render dimensions to 300 dpi , select Render to exact resolution , open image in Photoshop and its 72 dpi , whats going on with this ?
Poser 6.03.139
Thanks Rod
stewer ( ) posted Tue, 29 August 2006 at 6:30 PM
What file type are you using to save the image?
RodB ( ) posted Tue, 29 August 2006 at 6:42 PM
Exporting as a PNG to get transparency Stewer !
Rod
RodB ( ) posted Tue, 29 August 2006 at 6:48 PM
That was it Stewer , output to PSD and it was 300 dpi , but now the problem is PNG is the only one to give transparent background !
Rod
JenX ( ) posted Tue, 29 August 2006 at 7:40 PM
You still have an alpha channel, and you can Rasterize the image, load the Alpha channel, invert the selection, and remove the background, and you'll still have a transparent background ;)
Realmling ( ) posted Tue, 29 August 2006 at 8:19 PM
If you're loading the render directly into photoshop you can open up the channels menu, select the alpha channel and tell PS to make it a selection, go back to the full color channel, and then copy and paste into a new document.
Just a shade quicker IMHO. ^_^
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser goodies and so much more!
RodB ( ) posted Tue, 29 August 2006 at 10:54 PM
Off course , alpha channel , thanks guys :)
Rod
dphoadley ( ) posted Tue, 29 August 2006 at 11:02 PM
Saving it as a tif file should also give you a transparent background, and preserve your dpi, no?  I always save as tif's.
DPH
EnglishBob ( ) posted Wed, 30 August 2006 at 3:59 AM
Poser doesn't care what the dpi is for a transparency map. The only time dpi matters is when you're sending a render to be printed.
