Sun, Feb 2, 3:12 PM CST
Subject: How to hide an object in Vue Easel
Dave_III ( ) posted Mon, 28 August 2006 at 10:02 AM ยท edited Sun, 02 February 2025 at 3:03 PM
It's either right in front of me or it doesn't exist: The terrain I'm working around keeps getting selected wheneven I try to click on a specific object in the scene I'm planning. Moving the terrain away (adding 1000 to the location coordinates) is simple enough, but it'd be easier to have it become "unclickable" temporarily, for blocking purposes.
How do I do this? Or am I out of luck?
nruddock ( ) posted Tue, 29 August 2006 at 7:43 PM
Create a new layer.
Move the objects you don't want to to be selectable to this.
To make them unselectable, click on the "eye" icon to the right of the layer name, it will turn into a "padlock".
To make the items in the layer selectable again click on the "padlock", then click on the "closed eye" (note don't try double clicking, as this will start edit mode for the layer name).
Dave_III ( ) posted Wed, 30 August 2006 at 9:29 AM
Ok, I've seen the "eye" in other programs, and I see nothing like that here, nor Layers. You are talking about Vue Easel, right?
nruddock ( ) posted Wed, 30 August 2006 at 12:55 PM
Quote - Ok, I've seen the "eye" in other programs, and I see nothing like that here, nor Layers. You are talking about Vue Easel, right?
I've got Infinite, so if layers aren't available in Easel, then there probably isn't a mechanism for doing what you want.
mommyphant ( ) posted Thu, 31 August 2006 at 3:33 PM
No layers in Easel, I couldn't find any
wabe ( ) posted Fri, 01 September 2006 at 2:11 AM
No layers in WEasel no "hide objects" in any other form - without moving them in one axe outside of your camera view.
I normally do that by adding a number to one axe that i can delete easily again. For example simply add 111 in front - and remember later that if you delete those "111" the object is in the correct position again.
