Fri, Nov 22, 10:34 PM CST
Renderosity Forums / Hardware / Technical
Welcome to the Hardware / Technical Forum
Hardware / Technical F.A.Q (Last Updated: 2024 Aug 27 11:07 am)
Welcome to Hardware and Technical
If you have any trouble with your computer equipment or just want to find out about the latest toys then this is the corner for you. Pocket protectors optional!
Subject: Overclocking Q
cainbrogan ( ) posted Sat, 21 April 2001 at 9:50 AM · edited Fri, 22 November 2024 at 10:33 PM
Hi All, Where can I find info on overclocking my system? I've a DFI P5BV3+ REV:83 an AMD K6-2 350 and will be upgrading to an AMD K6-2 550 soon, so am figuring now would be the keenest time. Thanks Ahead of Time, Cain~
ookami ( ) posted Sat, 21 April 2001 at 10:03 AM
I don't know that this is really the right forum to be asking overclocking questions... but here's a few places you can try: http://www.tomshardware.com (the BEST) http://www.hardwarecentral.com/ and probably a few others I can't think of off the top of my head. Personally, whenever I have overclocking quesitons... I go to Tom's site.
cainbrogan ( ) posted Sat, 21 April 2001 at 10:50 AM
My PC is down right now, I'm at my library without my newsgroups and I saw a Q about here last week so I figured It would'nt hurt to ask. Thanks. = )
darchangel ( ) posted Sat, 21 April 2001 at 11:47 AM
amd k6-2s dont overclock very well. you could possibly overclock the 350 to 400 mhz but you wouldnt notice any performance increases. i suggest you just stick it out and leave it at 350. although i do have a 450 mhz k6-2 (my win2k server) that ive ran for the last year at 492 or something mhz, but ive noticed larger performance increases there because i increased the bus speed to around 112mhz and it overclocked all of my peripherals as well because my ram speed/pci bus/etc all benefitted from the higher bus speed. toms hardware is a good source, but seriously i think its not worth the trouble to overclock a 350 when youre upgrading it soon anyways. k6-2s are already pretty much overclocked when you buy them, heh... if youre buying a new cpu, you can get a duron for a very low price these days and itll vastly outperform a k6-2 or even a celeron. the fpu on a k6-2 is very weak, and poser is quite fpu-intensive. i have it installed on the k6-2 i mentioned above and it runs agonisingly slow. it renders fast enough, but when youre zooming and rotating the figures it bogs down quite a bit, even with 384mb ram. youd be better off to spend a little extra and get a duron 800 chip and a new motherboard like the asus a7v -- it will also give you the option of upgrading to an athlon thunderbird in the future if you get some more cash. durons are the most power for your buck right now.
cainbrogan ( ) posted Sat, 21 April 2001 at 12:08 PM
I'll be purchasing a new CPU as soon as I can find out which is the fastest for my board. DFI's Tech. Supp. rots, thier page for my MB list the boards with the names changed and They want your whole system down to drivers before you can submit thier inquiry form! Should I try to overclock then, it'll probably be a K6 2-550?
ScottA ( ) posted Sat, 21 April 2001 at 3:02 PM
Moving this to the hardware forum. ScottA
