Sat, Jan 25, 12:53 PM CST
Subject: can you render with no background...?
DarkEdge ( ) posted Fri, 08 September 2006 at 1:33 PM · edited Sat, 25 January 2025 at 12:52 PM
is it possible to render with shadows but have no background?
nomuse ( ) posted Fri, 08 September 2006 at 1:46 PM
Poser will always put some background color in there. However, it is a solid color; it is easily selected within PhotoShop or a similar editing program to be replaced with the content of your choice -- or make into the alpha mask of a transparency.
jonthecelt ( ) posted Fri, 08 September 2006 at 1:47 PM
If you save your image as either a .png or .tif file, then an alpha channel is automatically included for you, which you can then use to remove the backgroun in your image-processing software of choice.
jonthecelt
DarkEdge ( ) posted Fri, 08 September 2006 at 1:52 PM
okay, well i am saving as a tiff and i have ps/cs2 but when i go to the channels layer all i'm seeing is rgb channels....no alpha! is this something i have to setup in poser render? also, when i opened the tiff in ps it asked if i wanted it to correct color to rgb...i said no. is this what i want?
DarkEdge ( ) posted Fri, 08 September 2006 at 2:02 PM
ahhhh, that was it. convert to rgb and the alpha channel is right there. thanks all.
nomuse ( ) posted Fri, 08 September 2006 at 2:02 PM
I guess the question is, what is your ultimate goal? Are you trying to make a stamp, or a graphic with a transparent background, that you can use on a web page or something? Or are you trying to put a custom background into a rendered Poser image? Or do you not like the default background color and since you can't decide what color to use, you'd prefer "none?"
masstapro ( ) posted Fri, 08 September 2006 at 2:05 PM
rgb should still have the alpha channel (need to save with millions of colors set to ON in other programs)
remember being able to deselect world/background when exporting in P6
thefixer ( ) posted Fri, 08 September 2006 at 2:50 PM
If your background colour in Poser is grey and you save as a png then your background will be transparent in any 2D package like photoshop etc. No big problem!
Injustice will be avenged.
Cofiwch Dryweryn.
thefixer ( ) posted Fri, 08 September 2006 at 2:53 PM · edited Fri, 08 September 2006 at 2:54 PM
Anad another thing, don't forget you can render the image without shadows and save as png, then render the shadows only and save as png. You can then composite the 2 in PS and add the background of your choice!
This is really good because with the shadows as a seperate layer you can adjust them in any way you want without affecting your colour image!
Once done just flatten layers, save as a jpg or whatever and there's your completed image.
Cofiwch Dryweryn.
pakled ( ) posted Fri, 08 September 2006 at 3:13 PM
that would help. Like an idjit, I posed my character in Poser, took him to Bryce, set up shadows, and then couldn't get a good angle to show the shadows..;) was going to save with the camera just in front of the character (but behind the shadow), to get that in there..the things I come up with..;)
