Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 18 12:40 pm)
If it's not a poser model like these ones...
http://www.geocities.com/SupermotoXL/
These are in 3ds format. Import the car and on the Prop Import Options dialogue, enter a value in the "Percent of standard figure size". I start with 125 and play around until it works.
Note the cars from the link above will 'break up' in Poser (see picture so the one here is probably the better one.
Seen this breakup happen before something to do with max models I think. Anyone have a solution for this ?
Quote - Seen this breakup happen before something to do with max models I think. Anyone have a solution for this ?
If by "breakup" you mean different parts import out of place, then it's because the creator didn't do a "reset xform" before exporting to 3DS.
The black triangles are probably polys with reversed normals.
I saw cyborgx by Rexxzilla in marketplace. Can V3 fit inside of the car? I mean as a driver or as a passenger?
