Thu, Nov 14, 2:16 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Using Morphs on Jessie
Stelwire ( ) posted Wed, 13 September 2006 at 7:02 PM · edited Wed, 13 November 2024 at 3:52 AM
I bought RDNA ultimate body morphs for Jessie and have followed the installation instructions but cannot get the 'dials' to show up - thus I think that they are not loaded.
I poseted on RDNA a question and received the help file which comes with the download - no real help.
Simply put I:
Open Poser
Select High Res Jessie
In poses click on the FBM icon
nothing happens.
Anyone have an idea what I may be doing wrong.
svdl ( ) posted Wed, 13 September 2006 at 7:20 PM
The RDNA ultimate body morphs only work on Hires Jessi with genitals turned ON. The default figure that shows up when you start up Poser is not Hires Jessi, it's Casual Jessi, one of the lores varieties. Delete her, and load Hires Jessi Nude from the Figure library.
Then make sure that Genitals are turned ON (Figure menu).
The version of the RDNA Ultimate Body morphs I have consists of a series of poses, the first of which is called Setup. You should start with that pose, it'll insert the required channels and groups into Jessi, turn of inverse kinematics and set her in zero pose.
Then use one of the morphs that include the word 'Cat' (for category). Some of the morphs only create the groups, others also inject the morphs themselves. My personal preference is for using AllHeadBodyAndCat, which simply injects everything.
When I juse Jessi, I also use the following method to make her look more realistic:
  • scale hands, fingers, feet and toes to 90%
  • Xscale shoulders to 110%
-Xscale forearms to 90%
Hope this helps,
Steven.
My gallery   My freestuff
Stelwire ( ) posted Wed, 13 September 2006 at 8:06 PM
Will try it again, but of note.
I start with blank scene/load hi res jessie/load FBM pose - nothing happens  (genitals on/inverse Kinematics off)
I have also started with deleting James (startup character)/load Jessie Hi Res/load Jessie Hi Res FBM (figure)/load Jessie Hi Res FBM (pose)  same result.
Hence my puzzlement.
svdl ( ) posted Wed, 13 September 2006 at 8:49 PM
Oh, often the properties palette doesn't refresh correctly. Try selecting another bodypart (using the dropdown on the properties palette) and see if the channels appear.
