Try using the Animation Toolbox (Animation menu)-- select your helicopter, go into the toolbox, and select the loop option of the repeat mode. Or, I believe you can just copy and paste the first 30 frames into the next 30 frames. Dragging the timeline out will only change the time over which your rotation/translation occurs, so it will slow down or speed up your animation but not add keyframes.
I have not animated a helicopter yet but maybe an idea. #1 lops are something internal in Poser and are obviously not brought over to Vue - maybe you signal that to e-on so that they can look into that.
#2 you stretch your one rotation to the full anymation time and then apply a time filter to the animation. There are repetition filters for what you ask for already from e-on that give you an idea how to do what you need. Saw tooth is the key word here.
I made a 30 frame animation of a helicopter rotor in Poser and I made it loop. I then imported the helicopter into Vue (30 frames). I then animated the Hellicopter over a terrain (60 frames long) My problem is this: The helicopter rotor stops rotating at frame 30 even though I made it loop in Poser. Shouldn't the rotor rotate continuously in Vue since it was made to loop in Poser? I tried dragging the propeller frames in Vue from 30 to 60 frames, but then they slowed down because the rotation is being spread out over a longer period of time. Has anyone successfully animated a helicopter in Vue who could offer some advice?
